Liverpool MV question
So my "non traditional" Liverpool has PPIMV. Am I correct in assuming because there is no -bias voltage that connecting to the board for ground is not needed and I can connect to ground directly? See the blue wire at the board can that go straight to my ground buss?
						Re: Liverpool MV question
Hi,
correct, direct to ground buss if you have all grounding on one buss. If not, and you have your first cap separate grounded, than try there or to grounding point of bias resistor. Where is the lowest noise - there are you at home.
I have diff. groundings for preamp and power amp. So my best place for LarMar MV is bias R.
Best
Hans-Jörg
Best
Hans-Jörg
