Has anyone built a Liverpool without a bright switch?  I had a Liverpool in the past and the switch introduced noise to the amp.  I never really had a need for it either.
Does anything change sonically?
						No bright switch on a Liverpool?
Re: No bright switch on a Liverpool?
Colossal's trick of turning the volume pot 90 degrees anti-clockwise shortens up the bright switch wiring. Then glue the cap(s) to the switch.
Lots less noise.
									Lots less noise.
Why Aye Man
				Markusv
Lately i leave mine on off position more and more
but you do need it sometimes especially with humbuckers
.........Now where did I put it?
A 2 pole, 3 position, center off switch gets you 3 choices.
Why Aye Man
				Markusv
Precisely
also short wire or no wire if possible
