New Rocket Build Bias Resistor issue
HeeBGB
Site Admin
Post by HeeBGB »
OK so i completed a new Rocket build over the weekend. I posted some details about it a while back. It is in a custom chassis. The chassis is the a Blues Junior style and will fit a custom cab I have. So basically a rocket circuit in a custom Blues Junior cab and chassis.
In any case the issue is that I used a PT that has a bit too much voltage. over 390 at the plates and about 385 at the screens. I am having issues with red plating. I used the standard 50ohm 25 watt cathode resistor. Is it possible to run EL84's at this voltage with a larger cathode resistor?
Here are some pics.
[IMG:600:800]http://i14.photobucket.com/albums/a330/HeeBGB/Rocket/IMG_3224_zps68d6adf1.jpg[/img]
[IMG:600:800]http://i14.photobucket.com/albums/a330/HeeBGB/Rocket/IMG_3223_zps53d62559.jpg[/img]
redshark
Re: New Rocket Build Bias Resistor issue
Post by redshark »
The standard 50 ohm could be too much even with proper voltages so increase it to @ least 80ohms and see what happens!!
Good luck!! :)
HeeBGB
Site Admin
Post by HeeBGB »
Thanks. Can I get away with a lower wattage resistor? The one called for is 25watts. I have a 100ohm but only 10watts
redshark
Post by redshark »
Not so sure about that!! :(
sliberty
Post by sliberty »
If you want to try it, I have a pair of cement 200 ohm 10W resistors that you can try out (just don't cut the leads please). You can parallel them for effectively a 20W 100 ohm resistor. Should be close enough.
RJ Guitars
Post by RJ Guitars »
I know there are several posts regarding using the higher voltage tap on a "standard" Rocket PT... seems like it was first brought up by either Allyn or 2-Tone. They settled on a 68 ohm bias resistor when using the 280v tap. I think this would keep things right on the ragged edge where VOX designed them to operate - for better or worse.
As mentioned above, 100 ohms is probably close enough and your tubes would thank you while your fans would never really know...
http://www.rjguitars.net
