I just want these tube chassis's to use as a sort of pre amp. I plug my bass into the RCA input of the amp, then line out of the tube amp into the mixer. The sound is phenomenal for recording and getting vinage bass tone. Especially on bass guitar. I remember Matt saying the amp I used has a tube that helps bass a lot, a tube called the 7027A. I don't really know what the difference is, but it wins my heart over the fender for any instrument really.
The speaker on the organ had a terrible voice coil, so all this time I thought that the amp sounded like crap, but once I went direct out of it I was amazed!
There is a trim pot called "hum balance". For some reason or another, and perhaps because the amp is dated 1959, the pot is stuck. The screw that fastens it on is stuck. I would KILL to be able to dial in that pot because there is slight hum depending on where I am standing. Does anyone know of a good evaporating cleaner/lubricant solution that will losen this pot? I was thinking about using DW-40 but I changed my mind
I spent a long while cleaning the amp and trying my hardest to get rust off of the chassis. The amp is finally clean and seems to sound better as a result of it
I really wonder who I can take this amp to for work? Two of the pre amp tubes dont light as brightly as the rest, and I guess I dont really know how stable this amp is. The tubes heat up rather quickly. Anyway, I just felt like posting, not necesarrily to harass anyone with newbie questions. Also wanted to post the photographs of the amp before I cleaned it up.
Best,
