Build Protocol for Wreck Variants
RJ Guitars
Post by RJ Guitars »
Amp Builders,
I am often asked for a build guide for Wreck amps, variants of Wreck amps, and misc other amps. In the case of pure Wreck clones, I generally suggest the Ron Worley build guide... although I don't do much amp cloning, I think it is probably a good resource for that effort. For my own builds I have established a protocol that allows me to efficiently and effectively put together an amp build. This is my attempt to consult with expert amp builders to further develop a protocol that a new amp builder can follow as a set of general guidelines, although In this case I am thinking primarily about Wreck variants.
FWIW - I typically tackle the build in stages and for this protocol development I will avoid getting too far into the details. I anticipate that I will need to edit this liberally until it has credibility... your helpful gentle spirited contributions are requested.
Wreck Variant Build Protocol - Rev 0.0 - April 5, 2014
1) Step one
- Gather up all the parts and do an inventory. Verify that you have a correct schematic and a layout to work from.
2) Step two
- Chassis prep work - this includes adding any extra holes to punch, drill or thread. After that I clean the chassis with warm water and dish washing soap - this works really nice for aluminum chassis'. I have always thought it would be great to be able to run them through the dish washer but my wife has no sense of humor about that idea. Once the chassis is clean you can do any painting, powder coating, or anodizing. If you want any labeling done by laser etch or silk screen, this is the final step in chassis preparation.
3) Step three
This begins the fun. Mount these items:
a) Any internal standoffs, ground tabs, terminal strips, or other items that mount directly below the
transformers.
b) Transformers
c) IEC socket
d) Fuse holder
e) Impedance switch
f) speaker jacks
g) Faceplate
h) Pilot light
i) input jack
j) On/Off and Standby switches
k) potentiometers
l) terminal strips and ground tabs
m) surface mount components (chassis resistors etc.)
4) Step 4
- Wire the Power transformer beginning with running the safety ground wire from the IEC socket to a ground point on the chassis - this is the only wire that uses these two terminals. Do not use this ground point for a signal ground connection. Then continue wiring the AC socket, on/off switch, pilot light. In a traditional Wreck the neutral wire is also switched. This is not considered a "best practice" in modern electronics, but is typical in a traditional Wreck build. Once the AC wiring is finished, tie all center taps to ground as appropriate, and heater wires to either a terminal strip or the first tube they feed, whichever is appropriate.
5) Step 5 - Wire the secondary of the output transformer to the impedance switch and any other connections that can be made before the power supply is created. Don't connect the B+ wire or any other wires to the primary side of the OT yet.
6) Step 6 - Wires the tube heaters. This is usually one of my least favorite tasks, especially on a Liverpool or Rocket type of build because they have so many tubes in them. I prefer to use two colors of #18 stranded wire for the tubes. I twist the wires together by taking about 24" of each wire and clamping on end of the pair in a vice, then the other end I put into my electric drill... you can figure out what to do next... you'll never be tempted to use a loose sloppy twisted pair if you do this. from the length of twisted pair I cut the correct length to go from one tube to the next, always using the same color wire on the same pin for each heater in any given type of tube.
7) Step 7
- At this point I suggest some electrical testing. Make sure you put a fuse into the fuse holder. Do a visual inspection and make sure every hot wire is connected to a safe and proper place and/or is properly insulated or isolated to avoid an electrical shock or short. The most important wires to verify are the high voltage taps from the power transformer secondary... make sure again that they are completely insulated and isolated from touch each other, the chassis, and you. If you have properly wired things up to this point, the light should come on and power transformer will create the appropriate voltages. Using an insulated connection you can measure the high voltage coming across the secondary B+ taps. You can also measure the heater voltages across the heater taps, and then to each individual socket. If all this goes well, verify that everything is again insulated and isolated and you can put a tube into each socket and verify that the the heaters light up... this often gives me a great feeling of accomplishment.
8) Step 8 - I will trivialize this for now by saying"wire up the power supply". This will require more information and detail later. After it is wired up, make lots of measurements and recognize that at this point you have energized the filter capacitors and they are carrying potentially lethal voltages. After you unplug the amp from the AC mains power, you will need to short them to ground before sticking your fingers into the amp to do any further work.
9) Step 9 - Install the preamp board. Some folks prefer to mount the components before they put the board in, other do it with the board in place. I've done it both ways but which ever way you choose, make sure you have all the wires and connections complete on the back side of the circuit board before you mount it in there. Hook up the B+ connections and grounds to their appropriate locations.
10) Step 10 - Install and wire the components to the power tube section, including the connections back to the preamp board. Again, I have trivialized this and details will need to be filled in later.
11) Step 11 - Wire the phase inverter between the tube and the preamp board. Details needed...
12) Step 12 - Wire the gain stages in descending order, between the tube sockets and the preamp board.
13) Step 13 - Wire the input jack.
14) Step 14 - Wire the volume control and tone stack.
15) Step 15
- Verify that everything matches the layout and agrees with the schematic.
16) Step 16
- Power up the unit... if you feel the need and want to be cautious, you can use a light bulb limiter or other forms of circuit protection. In modern amps with modern components, the filter caps do not need to be "formed". This only is needed with very old caps and I don't suggest you use them.
17) Step 17 - put in tubes and hook up a speaker or some sort of load on the output. Tube amps do not like open circuits on the output section and it can ruin your output transformer if you don't attach a speaker cabinet. I always use a shorting jack for the speaker output so that if you forget to hook up a speaker, the amp is shorted to ground - this protects the output tranny.
18) Step 18
- If all is well, your amp is now ready for sonic testing...
http://www.rjguitars.net
Richie
Re: Build Protocol for Wreck Variants
Post by Richie »
I don't think everyone builds the same way or in the same steps.
But with these amps, i'm sure its best to do some things first,before others,so you don't have those.."oh crap" moments..:)
Ken Moon
Post by Ken Moon »
I think this post will be super useful to a whole bunch of guys - thanks, RJ, for putting in the effort to lay it out so clearly.
RJ Guitars
Thanks guys, those are encouraging words coming from knowledgeable guys like you. I wanted to provide folks with all the help they need to build an amp, especially if I sold them a box of parts. However, having access to the eyes and minds of the TAG forum is better than anything I could ever offer in tech support. I think it's also very cool to see the amps come together and then go through the tweaking process... It seems I still learn something on every amp thread that is posted.
Post by Mark »
Perhaps the amp face plate could be fitted later so it isn't subject to accidental damage?
Yours Sincerely
Mark Abbott
Richie
Post by Richie »
Mark wrote:Perhaps the amp face plate could be fitted later so it isn't subject to accidental damage?
that is easy to do,or could also just leave the pilot light not installed, and not put the faceplate on till later. Just snug up the switches and pots and wire those up.
Or if you build very many of these amps, you can make a faceplate to do a mock up and some of the wiring of the pots/ground buss so you can lay the pots flat down,or backside up for easy soldering access.
Less mess inside the amp too for anything that can be soldered outside the chassis.
plus at the start,measure the "parts" caps, resistors, etc. Mostly the pots too to see what value they are and the slope/taper of them. I probably go though 20 pots to find one I like or that has the slope/taper I like.
I also like to mount the transformers later. its easier to flip and move the chassis if it doesn't have the transformers mounted. I think Rons build guide was also pretty good. Probably depends on if someone is a beginner or more experienced. Little tips or tricks.
what about step 19 enjoy your favorite brew or smoke then RTFO
RJ Guitars
Those are good additions guys... I really wanted to write this down to share as well as to check myself and see if I am consistent and thorough in what I do.
Fitting a faceplate and then setting it aside can be pretty important. for a wood and even occasionally on a metal one, I'll clear coat them once I have the final drilling and fitting done. That really glosses them up and gives a great look to them, but it also can be scratched pretty easy so I often tend to wait til the amp is working in some sort of satisfactory way before I put the final clamp down on the faceplate.
Measuring component values is an important step and I have been burned a few times by ignoring this... recently in fact I put in a brand new filter cap that was a dead short. I looked way too long and hard to find my error before the bad cap was obvious, could have saved myself some trouble. Despite modern manufacturing techniques, I see capacitor values vary wildly within a given brand if I take the time to measure them. In the attempts to get things close to a known good standard this is well worth the effort to do before you put a part in an amp. Occasionally I actually see a part that is entirely mis-labeled... that can really mess with your results.
thanks for the notes, I'll add these thoughts into my steps above.
As for step 19, that is of course optional but at the very least you should sit back and enjoy you creation. It should bring a smile to your face or otherwise you might not be ready for step 19 yet??
rj
