You mean like this?
This is the html version of the file
http://blueguitar.org/new/schem/trainwreck/kf_dlm.pdf.
G o o g l e automatically generates html versions of documents as we crawl the web.
To link to or bookmark this page, use the following url:
http://www.google.com/search?q=cache:ZW ... +amp&hl=en
Google is neither affiliated with the authors of this page nor responsible for its content.
These search terms have been highlighted: dirty little monster amp
Page 1
Top of Thread
EXPAND
geoaron@geocities.com)
Date: 5/8/2000 9:43 PM
Subject: Dirty Little Monster - review/FYI
Some of you wanted to know a little more about the "Dirty Little Monster" Trainwreck
Prototype so here's my take on it....
I got to play the Dirty Little Monster amp (Train Wreck prototype) the other day. It looked like
a typical Train Wreck amp but with labels for the knobs. I played it through a two 12" celestion
greenback cabinet (I think they were 16 ohm speakers???). I wish I had more details but I didn't
have that much time to check things out that much.
It's an 8 watt amp I believe and it can get pretty darn loud for what it is.
How can I describe the tone???
The highs are crystal clear - and there's a twinge of "angry-ness" at the very top. Like a "biting"
tone at the very top of the timbre. The lows are tight, yet complex, mids are fantastic. With the
volume control of the guitar, the amp goes from crystal clear to angry and distorted. With a
Strat/Fralins it went from extremely clean to beyond a bluesy tone - with a turn of the pot. You
could easily play rhythm and then jump to lead with a turn of the pot. I played 2 or three Fender
strats through it and you could hear each guitars tone.
However, even when dimed, it had just a tad too little drive for the over the top kind of liquid
soloing I like.
Luckily I had my FET drive with me. For those of you who don't know, my FET drive/AKA
Booster 2.5 has 2 Jack Orman Mini-Boosters in series tuned somewhat like an tube preamp
(22uF bypass cap on first stage,100 ohm resistor) to Marshall style 470K/470K voltage divider
with 470pf high pass filter to 1Meg pot with .001uF treble "bleed" cap. This then goes to a 2nd
stage into a tone control. This is all based upon Jack Orman's Fantastic Mini-Tubes preamp.
Man, what a combination! With just a little boost from the FET drive, this thing went from
totally clean to singing sustain with BITE! You could get everything. Angry sounding leads to
more "closed" sounding liquid leads using the FET drive as the distortion circuit.
I noticed the amp was fairly bright and I had most of the Treble control turned down almost all
the way. There's only treble and bass I think and there was a peculiar pot that only worked when
the Master was used. Yes, there was a Master Volume on this one.
My guess would be that the pot somehow affects a treble bleed cap across the master volume?
That would explain why it only worked when the Master was used. There was another slope?
Page 2
control and I guessed this to mean that it affected the slope of the tone controls.... I wish I knew
more but that's about all I know.
I know this reads like an ad, but I wish I owned this thing. Well, I own the pedal.
Went back to my Fender Bassman and oops - where's the clear highs with complex mids and
lows.... Hmmm.... left back at Hilo I think.
Hehehehe
Aron
PREVIOUS
EXPAND
Date: 5/11/2000 12:52 AM
Subject: Re: Dirty Little Monster - review/FYI
sounds like some really Cool stuff!
What kind of tubes were in there?
JAY
PREVIOUS
EXPAND
steve_ahola@yahoo.com)
Date: 5/12/2000 2:56 AM
Aron:
So who makes the D.L.M.? Any chance that you can sneak a peek inside to let us know what
is going on in there?
--Thanks!
Steve Ahola
PREVIOUS
EXPAND
Page 3
Date: 5/13/2000 12:43 AM
The DLM is a prototype Train Wreck from Ken F. I guess it was some sort of proto amp for
low power.
It's in Hilo and I live in Honolulu. Maybe the next time I can look at it - I'm not sure.
The thing is.... I mean.... look at the Express schematic - there's nothing amazing about it. I
guess what you are looking for is the brand and values of certain caps and perhaps the tubes and
transformers.
I can tell you one thing, this Wreck is bright. It has a biting high end and like I said, the treble
was fairly turned down - sometimes all the way.
Man, that seems to coincide with the 50pf vs. 470/220pf issue.
It's WAY brighter than my Fender Bassman's normal channel.
PREVIOUS
EXPAND
Date: 5/14/2000 6:15 AM
Aron:
So Ken Fischer is back in business producing guitar amps? Or is this maybe one of his
"authorized clone franchises"...
Sometimes it is the simple designs that make the best sounds. BTW the Wreck Express
design is quite unlike practically any amp that came out before it. Although the tone stack is
placed after the first stage like a BF amp, the connection to the mid pot is like the
5F6A/Marshall tone stack (as are the cap and tone pot values). And compared to the Normal
channel of the BF amps there is a third gain stage before the PI (which is much more like a
Marshall than a Fender). So this beast is not quite animal or vegetable, so to speak.
You are right about the caps and trannies contributing to the unique sound; I also believe that
KF fine-tunes each and every amp that he sells...
Steve Ahola
Page 4
P.S. Did you notice what kind of wood the head was made out of? < grin >
PREVIOUS
EXPAND
Date: 5/17/2000 12:53 AM
Not that I know. I think this is one he had around his house. My friend was very lucky to get it.
>BTW the Wreck Express design is quite unlike practically any amp that came out before it.
I stand corrected.
I see. I haven't studied enough amp schematics to know what is unique or not I guess.
>I also believe that KF fine-tunes each and every amp that he sells...
I'm sure of this. Also he is extremely picky about each set of tubes too from what I have heard.
I better check. I could hear the difference if I put my can of soda on it. Really made a difference
in the mids.
PREVIOUS
EXPAND
Date: 5/19/2000 3:33 AM
aron:
And I was thinking that you had just seen this amp in a store... You better make a complete
set of photos of the inside of the chassis for your friend— you know, for insurance purposes if it
ever caught on fire...
And experts recommend storing a set of backup files as far away from the originals as
possible so you can send the backups to me for safekeeping. < grin >
Page 5
If I seem to be overly enthusiast about the Trainwreck Express design (probably not entirely
different from your friend's DLM!) it is because I have been hearing from so many people who
have been building amps based on the Expresso schematics posted last year, and they have been
really knocked out with the results.
--Thanks!
Steve Ahola
P.S. You better measure all of the plate voltages, too... for insurance purposes so that a
like-for-like replacement could be built.
