I have several questions, as this build was quite a bit different than richie's layout and has dual external bias pots. There are no layout or schematic diagrams with dual bias and this is causing me some confusion.
I have changed everything to richie's layout except what I think is dual bias related and when I turn on the amp and turn off standby it screams a horrible tone and there is a blue glow in v4 (EL34). I turn it off immediately. It worked OK before my changes.
First, the heater wires from v2 to v3 switch polarity (4+5 on v2 connect to 9 on v3 and vice versa), is this a problem?
Restoring a clone to richie's layout
Re: Restoring a clone to richie's layout
Sounds like your negative feedback is coming back in phase. Swap the 2 OT primary wires (Ususlly red and brown) on the plates of the El34s and that will probably cure the problem.
Thanks Dana, that solved that problem! I've never heard of that in all my perusing of this forum and the Plexi Palace and MetroAmp forums. I removed all the dual bias stuff since I couldn't quite understand it or get the current down low enough. The tone now is very good, much better than when I got it, but the sustain is crackly and almost like there is a gate on it. No hum or hiss though.
It appears that a just purchased NOS Tungsram was causing the crackling, so that's taken care of, but it still has no sustain, it's like there is a strong gate on. Is this "blocking"?
