Why are Expresses so unstable?
Re: Why are Expresses so unstable?
I don't understand why people want a balanced PI in musical instrument amplification?
(deleted)
EtherealWidow
I just love how this amp breaks a lot of text book rules but sounds amazing.
I haven't found Liverpool amps to be unstable, I haven't thought Express amps to be unstable provided you follow good lead dress.
Yours Sincerely
Mark Abbott
Mark Abbott
I think they're unstable cause both transformers are on the same side.making it want to tip if you grab it by the middle.
Also, the chassis on those is quite thin. Be careful throwing it into the tourbus!
I've often wondered if that flimsy chassis wasn't responsible for some harmonic content.
+1, like the trem springs on a strat....martin manning wrote:I've often wondered if that flimsy chassis wasn't responsible for some harmonic content.
vibratoking
Can I ask more about your theory? What is the mechanism? IMO, my Express sounds the same whether it's sitting on the speaker cab or away from it, unless I have noisy tubes subject to vibration. Also seems like the harmonic content would change depending on how tightly the chassis is bolted to the cab. Just wondering about your thoughts.I've often wondered if that flimsy chassis wasn't responsible for some harmonic content.
i've never used the thin chassis, but i too have wondered if that leads to some issues.
i've done two liverpools and one express. neither liverpool gave me any issues and one of them deviated from lead-dress to a high degree. not sure why but the express seemed to be more particular to what pre-amp tubes were used. strange since they're preamp and PI layouts are so similar.I haven't found Liverpool amps to be unstable, I haven't thought Express amps to be unstable provided you follow good lead dress
That was very funny!cbass wrote:I think they're unstable cause both transformers are on the same side.making it want to tip if you grab it by the middle.
BIG Dave: '63 Princeton, '67 SFDR, '68 Marshall 4x12, '71 Marshall JMP50, etc...
