Liverpool critical voltages
Re: Liverpool critical voltages
That PT is quite a bit over spec'd on the HT Taps. The Liverpool uses a 260-0-260 PT, thus you will have to find a way to drop voltage, or use a different PT.
There is nothing wrong with mating the Liverpool to a Marshall 18watt PA, but you'll have to tweak it to get it right. I am actually in the process of building an 18watt Liverpool that I will share info on when I'm done.
Ken designed the Wrecks to distort in the PA, then the PI, then the clipping stage of the preamp. An 18watt PA shouldn't have many issues with doing this as it is designed to have primarily PA distortion with a little PI distortion as well.
If you look at the Mark Abbott schematic, he notes all the different rail voltages, but no specific test points. I haven't seen a schematic with voltages either, and I don't have one on hand at this time to measurements from. You can calculate what each voltage should be if you want to.
Try doing a search. I thought I've seen them posted at one time or another.harryk wrote:I was asking plate and cathode voltages of Liverpool but nobody is responsing. Are they a top secret or what is the reason not to share them with me? To me it would be a big help to get these voltages to adjust my Liverpool. Regards Harry
There are no big secrets. You ask a question and expect folks to hand you the answer (in less than a day)? Do some research first.
Actually guys (and gals) Harry has a good point. ON 18watt.com they had made up some downloadable forms which listed the pins on each tube and a column so you could record voltages - some of the more experienced builds by Richie and Graydon etc etc were then posted on the site so other builders and experimenters could see if they were in the ball park.
I found it reasurring and very helpful. Maybe we could do something like that here?
https://tubeamparchive.com/viewtopic.ph ... ol+voltage
for the power section. Preamp voltages are a bit dicier.
:DOne stupid question concerning Liverpool rail voltage resistors. There is a 1 kohm/25W resistor between B1 and B2 which is 25 W. Is there a real reason for that huge wattage. To my mind reducing voltage and dissipation do not need that big resistor. Normally these resistors are of 3-5W in the rail. Am I wrong? Regards Harry
Welcome, Mr. Bluetone. Was wondering when you should enter
It seems there are a few TW clones in Finland and you're making a few more
Cheers!
Humbucker, a proud owner of two Express clones.
Cheers!
Oldie newbie.
Hi Bluetone,
no clue but some things are best left unanswered...
but seriously, it is overrated; I'll check it with a knowledgeable friend and get back to you a.s.a.p.
BTW, you should inject some clips to your net site. Eyes don't listen
Oldie newbie.
