Hey fellas, I'm new here so excuse me if this has been covered.
I just bought a clone & was wonderring what your experiences might be with the following ref bringing the volume down for home use.
A: Yellowjackets w/EL84s
Weber MASS or other attenuators
Palmer PGA-04
B: Other attenuators
Half power switches
Power scaling
I've got A & am very interested in B. Anyone try any of these & what were the tonal results?
I know tone is subjective & anything you use is gonna alter the tone....just wonderring if one worked better than the others.
Thanks !!!
________
Alcohol rehab dicussion
QUESTION...
QUESTION...
Re: QUESTION...
Hi.
I use a dr.Z airbrake, modded so I can go down to 0 W! (never use 0 W).
In fact I found that the bedroom level even at minimum was too high for my bedroom, so I modded it in order to have a lower volume.
I'm very satisfied with the sound even at this low level.
Before I had a THD but after buying this unit I sold it.
Logically at this very low bedroom level the feeback is reduced and somethimes you can not have it, but the overall sound is very good.
Castor
Castor
Re: QUESTION...
Puck, I'm not a big lover of attenuators but, there is a layout for an airbrake on the site or you can buy one if you go that route.
Re: QUESTION...
Thanks Allyn.....
I've got a Weber MASS & it's O.K.
The Yellowjackets are actually cool, but sometimes the circuit doesn't really jive w/EL84s....this might, but we'll see.
The Palmer is actually very cool. I run the amp to the Palmer out to a small mixer w/headphones & use it for the appropriate volume. I haven't tried it as an actual attenuator, but it does it's thing fairly well....maybe add some powered monitors.
But of course, I haven't even received the amp yet & I'm dying to try it full bore thru my Port City Wave 2x12 loaded w/2 G12-65s from the early 80s.
________
Roor bong
________
Roor bong
