Rocket Build OT Question
JoeCon
Post by JoeCon »
Guys
OK newbiew question: on the OT secondary I put the 16/8/4 ohms to a switch. The output of the switch goes to the tip of the output jacks, switchcraft type. Now does the common wire goes to ground or the body of the plugs? Which are really at ground thru the chassis anyways. Confusing??
Thanks...
Blackburn
Re: Rocket Build OT Question
Post by Blackburn »
The common (Black) wire from your secondary can go to the grounded lug of one of your output jacks. Common in Wrecks.
JoeCon
Post by JoeCon »
Thank you sir!!
