Couldnt have said it better myselfIt seems this blind taste test has put to rest the misnomer that you cant make a clone sound as good as the real deal.
JOE
Well the first thing to do is not tweak it at all, but to look it over and see if there is a problem somewhere. This amp was more my experimental amp. which i had changed a few things over time. But it was still mostly like the express. It could be so many small things or something simple causing it not to sing or hold notes like it should. So i won't really know untill i get to look at the amp. Many things like values of pots and resistors can make a difference,even small changes can sometimes make or break it to be responsive. It could have had something jar loose in shipping etc.. On the other hand, you can also have an amp that will feedback too soon,or may not have any cleans. So you have to get the balance going. I'll keep you posted on the detailsgcenker wrote:Richie,
just curious (and a noob who's building his first clone), how does one go about tweeking an amp to make it have more compression, sweetness and harmonic feedback?
I was always under the assumption it has to do with biasing, choice of iron, tubes, caps and sometimes just blind luck.
I have Toneslut iron, Sprague PS series caps, removed the power resistor, replaced it with a 10H choke and have my amp biased at about 45mA. I seem to have feedback on demand - especially when using my LP Custom.
Just my 2 cents.
OOh faa, man, those Z amps! I know a guy who has a Maz 38 with 2x10's. While a decent sounding amp, not for me. He has to run the thing with an Airbrake, and at times , sounds real granular. And remember trying a RT 66. Yuk. Tone is in the ear of the beholder tho, might be horrible for me, great for you, so there you have it....Raja wrote:Yeah... ...anybody interested in a Maz 38 w/2x12's.....
Oh do keep me informedRichie wrote:Well the first thing to do is not tweak it at all, but to look it over and see if there is a problem somewhere. This amp was more my experimental amp. which i had changed a few things over time. But it was still mostly like the express. It could be so many small things or something simple causing it not to sing or hold notes like it should. So i won't really know untill i get to look at the amp. Many things like values of pots and resistors can make a difference,even small changes can sometimes make or break it to be responsive. It could have had something jar loose in shipping etc.. On the other hand, you can also have an amp that will feedback too soon,or may not have any cleans. So you have to get the balance going. I'll keep you posted on the detailsgcenker wrote:Richie,
just curious (and a noob who's building his first clone), how does one go about tweaking an amp to make it have more compression, sweetness and harmonic feedback?
Just my 2 cents.
Your right,sometimes in building an amp,it can be blind luck and turn out great. Or it can be a nightmare,and have all kinds of noise problems and not sound right. It could be from simple lead dress problems to about anything.
Funny here, I liked the clean tone better in Ritchie's amp! A little more glassy/chimey. It's really all in the individual's ears. Listening back tho, I hear the lack of the feedback thing. And if that's a big part of what you want, I get why you'd like yours more. Certain things about certain amps i like may be slightly tonally inferior to something else, but make me play better. If you don't have to think about playing and just go for it, makes for better music, doesn't it?geetarpicker wrote: Funny how some like the tone of the clone better. In some ways I agree on some sections, but definately not on others. I really like the warmer tone of the clean with the original amp, but I do like the crunchy stuff with the clone, though it didn't quite sing the feedback lead stuff but I already mentioned that.
