Rocket V1a Bypass Cap choices
JoeCon
Post by JoeCon »
Guys
I'm working on a rocket build with a switched bypass cap for V1a.
3 way switch with center position no cap ala the schematic.
Choices for caps I have are 1u, 10u, and 25u. Should I go for the biggest difference thus a 1u and 25u or something more subtle like 1 and 10 or perhaps 10 and 25??
Since I haven't heard the differences could someone explain the gain/tonal variations possible?
Thanks!
Re: Rocket V1a Bypass Cap choices
Check this out:
http://www.ampbooks.com/home/amplifier- ... capacitor/
This may not help you understand how it will sound, but it will definitely show you how much gain to expect, and why using a 25uF cap versus a 100uF cap will make no difference in tone or gain (to choose a blatant example).
1uf and 10uf switched is plenty good enough gain boost options.
Or go with SP3T mini switch for 3 way switching 1uf, 10uf, and 25uf.
JoeCon
Post by JoeCon »
Gentlemen,
Thanks!
I'm sure I'll have more questions as this carries on.
Joe,
This is how I did the boost on a Reverb Rocket build a few years ago. Poor quality picture but you should be able to see I used three separate turrets to separate out the bypass resistor, 1uf cap and 10uf cap.
JoeCon
Post by JoeCon »
I did a similar layout, will post pics when I get my camera going.
Thanks.
Joe,
I waiting for that photo :lol:
JoeCon
Post by JoeCon »
Hope this works:
Anyways I tied them together then ran individual turrets for each. So I can have the resisitor alone or with the 1u or 10u.
Yuppers that will work and really makes for a nice option.
