liverpool trem
				funkmeblue
liverpool trem
give me a good reason not to use that extra triode for a trem circuit....like something out of a princeton or ampeg rocket
						Re: liverpool trem
Because it is really meant to be a test in will-power to not use it for anything, and if you use it, you fail the test.
Really, I think we would love for you to try it and let us know how it goes. We worry that it will be hard to maintain the balance and order of clipping of the different sections of the amp while rolling up the guitar volume.
I'm curious though. I could see nothing lost if you are able to switch it completely out of the circuit whenever you want... unless use of amp real-estate causes noise issues...
				funkmeblue
Re: liverpool trem
it being bias modulating, when off it would be totally out of the circuit. I could add another tube that way I still have that extra triode sitting there doing nothing
						Re: liverpool trem
Haha! Touche!funkmeblue wrote:it being bias modulating, when off it would be totally out of the circuit. I could add another tube that way I still have that extra triode sitting there doing nothing
I wonder why we don't hear of it more often. Is it a space issue in a typical Liverpool? Hard to find location without having to move things around or make too much noise?
				funkmeblue
Re: liverpool trem
I built a 15 watt liverpool with a tube rectifier for a local player by  the name of Colin John who is an awesome slide player. Bias modulating trem and slide are very nice together....I know if I hit my blackface deluxe with a nice pedal and trem it sounds heavenly....
						Re: liverpool trem
https://tubeamparchive.com/viewtopic.ph ... ght=rocket
Trem circuit for a Rocket in principle should be adaptable to a Liverpool.
Re: liverpool trem
Go for it!  A trem of the bias circuit variety seems like a perfect fit.  None of the signal path is messed with and the gain structure remains "pure."
That should get you a nomination for the "Best Use of a Triode" award.
Re: liverpool trem
Ya, do it! If it goes well for you, I think I could be tempted to alter my liverpool too. Today, I'm busy about to install this infamous "presonance" control on my liverpool.Jana wrote:Go for it! A trem of the bias circuit variety seems like a perfect fit. None of the signal path is messed with and the gain structure remains "pure."
- RJ Guitars
Re: liverpool trem
Recently I have tried using the extra gain stage as a cathode follower feeding a line out circuit on an Express amp. What I am finding is that anything I change in the preamp circuit seems to take a little bit of the gain out of circuit and the "clean to mean" character changes. I hear this as a rounding off of the knee between clean and mean. I have not yet tried using the extra triode as a gain stage to boost the return from the effects loop rather than a cathode follower so maybe that will work. You might expect to experience a similar impact on the clean to mean behavior when inserting a tremelo circuit into the Express or Liverpool amp. On the other hand it might work out extremely well in a Rocket circuit since the clean to mean is not a factor in those amps. I wouldn't want to discourage you from trying it but rather consider using a switched bypass to take it in/out of the circuit in an Express or Liverpool build. YMMV
rj
									rj
http://www.rjguitars.net
