Rocket Hum
Re: Rocket Hum
Ahh don't give up yet.Have a beer, burn one don't look at it for a day or two.Come back when you're not frustrated
pics from different angles can help those trying to help you.
A new component thats bad is possible but its a lot more likely to be a bad connection or error on your part.
Re: Rocket Hum
Measure AC voltage at the B+ that should give an idea if your filter caps are filtering.
Re: Rocket Hum
+1 on the cover
Seems as though you have checked the grounding a number of times.
Have you actually measured the resistance relative to the chassis and safety ground.
Have you cleaned up the area at the ground connections to ensure you are connecting fully to the ground point?
Just because the hardware its tight is not always a good indicator.
mickephoto
Re: Rocket Hum
I checked all voltages and they are very close to the Ceriatone chart.cbass wrote:Measure AC voltage at the B+ that should give an idea if your filter caps are filtering.
mickephoto
Re: Rocket Hum
When I've used covers in the past they may have helped a bit, but not for this kind of hum.fishy wrote:+1 on the cover
No, I haven't done this. I'll try it. What would be a "good" value?fishy wrote: Seems as though you have checked the grounding a number of times.
fishy wrote: Have you cleaned up the area at the ground connections to ensure you are connecting fully to the ground point? Just because the hardware its tight is not always a good indicator.
This is worth looking into as well. The ground lugs to chassis seem very solid though. There are 4 in the layout - see photo. One thing that's different compared to the layout found here at AG are the way the filter caps ground. Again, I've tried plenty options.
mickephoto
Re: Rocket Hum
I removed the pots from chassis an isolated temporarily. Only connection to ground was through the bus wire. I had some hopes doing this, but it didn't help.badtweed wrote:
Also check to see if your bus bar connection to the back of the pots is getting a path to ground via the pots themselves. If so then you have a ground loop that you can easily fix.
Cliff Schecht
Re: Rocket Hum
Don't know if this got ignored or what but did you check that your hardware is all down tight?Cliff Schecht wrote:I had this problem with my Rocket and another amp at the same time. Turned out that both amps had loose hardware somewhere that was the source of a bad ground connection. It sounds like you are having a similar issue, either a ground is not connected securely or some hardware isn't tightened down. Go over every screw and bolt and make sure they are cranked down!
Cliff Schecht - Circuit P.I.
Re: Rocket Hum
They should be low resistance. I have usually measured o.1 to 0.3ohms. Make sure you see what the leads measure first.No, I haven't done this. I'll try it. What would be a "good" value?
Re: Rocket Hum
try adding a big choke ala Brian May/Pete Cornish (7h 260ma) between gz34 and OT. this should improve the filtering quite a bit
www.myspace.com/20bonesband
www.myspace.com/prostitutes
4x12" w/H75s
4x12" w/H75s
- dorrisant
Re: Rocket Hum
Eliminate this possibility quick and easy... I made this tester in an old 1/4" jack... took longer to make it than to actually test my OT! Turn the standby switch off, plug the tester into the main output jack and lift the OT wires going to the power tubes. Touch the wires to a 9v battery and release... If the bulb flashes, your OT is fine... end of test!mickephoto wrote:Is it possible that it could have something to do with the PT, or bad (new) filter caps. I'm not sure what else to try, except...
www.premierguitar.com/Magazine/Issue/20 ... ester.aspx
mickephoto
Re: Rocket Hum
I checked resistance on all grounds and they measure 0.4ohms or less.
The OT battery tester sounds like a good thing to try.
The filter caps are normally not oriented this way in a Rocket, but I had to due to space (chassis screws). Could this induce hum perhaps?
A few more photos...
Re: Rocket Hum
I did my caps the same way in two Rockets built last month. No issues.mickephoto wrote:The filter caps are normally not oriented this way in a Rocket, but I had to due to space (chassis screws). Could this induce hum perhaps?
mickephoto
Re: Rocket Hum
I measured about 2.5 volts AC on the B+ on startup. After a while it went up to 4V. Power tube plates all have the same AC (DC is 340). Pre tubes have almost no AC.cbass wrote:Measure AC voltage at the B+ that should give an idea if your filter caps are filtering.
mickephoto
Re: Rocket Hum
Good to know, thanks!xtian wrote:I did my caps the same way in two Rockets built last month. No issues.mickephoto wrote:The filter caps are normally not oriented this way in a Rocket, but I had to due to space (chassis screws). Could this induce hum perhaps?
Re: Rocket Hum
If you have the busbar soldered to the pots, the connection from the ground lug to the busbar is superfluous and a classic ground loop (see my highlights on your drawing below).
You also have a ground lead shared between the 3 x 22uF preamp filter caps and the 3 other HT main reservoir caps. These should have their own, separate lead to the ground lug per the layout (may well be your problem).
Happily, you can fix both of these by transferring the ground connection wire from the busbar to the -ve connection of the 3x22uF caps (& break the connection between these caps and the other 3 reservoir caps).
This may, or may not have anything to do with your problem, but it's bad practice in any case, so you should correct it. (I suspect this is what badtweed was alluding to earlier)
Also, do me a favour, and just check you have a 56k resistor in V2 cathode, not 5k6 - I can't make out the colours well enough in the photos.
0.02p
Andy
0.02p
Andy
