The amp settled at 75% plate dissipation. It cleaned up considerably, but I guess I could go even higher on the cathode resistors. The added cathode resistors looks like a hack job, so I'll order some new 10W and redo the bias board.
I'm running 12AX7's in V1 & V2 and a 5751 in V3. I might install a 12AX7 in V3 and drop the signal before the PI instead. I want the amp to have a high headroom. I have some JJ EL84's in there now. What EL84 tubes do you guys recommend? I have some NOS 12AX7 Mullards that I'll try out in the preamp.
I have to rewire the cut control, because it's now a presence control.
The amp is silent with very little hiss and no hum. I haven't added a shielding plate for the chassis, but I guess it might be a good idea for live use.
Clips will follow.
Joakim
