What sounds best with an Express?
I've got a couple G12H30s and was wondering if I should get a 2x12 8ohm cab or get a couple more speakers and get a 4x12 16ohm cab.
8ohm or 16ohm cab with an Express?
- Funkalicousgroove
Trannie taps?
Last edited by Funkalicousgroove on Sat Jul 12, 2008 2:58 pm, edited 1 time in total.
Re: 8ohm or 16ohm cab with an Express?
I got one of those Heyboer's that allows you to choose between the two impedences, that's why I ask. Also my speakers are 16ohm so I think I can only wire them for 8ohm?
Re: Trannie taps?
I have read that elsewhere before but also read Kevin O'Connor saying it is just wind in sails ( in speaker mfg sails to be more precise ).Funkalicousgroove wrote:If you have a trannie with 16ohm taps use a 16ohm load, that way you'll be using the full secondary winding of your OT, it will most likeley sound best that way.
Have you experimented with it?
- Funkalicousgroove
